door speakers with mach
Old Jul 10, 2008 | 12:51 AM
stallion11030's Avatar
stallion11030
Default door speakers with mach
What kind of speakers can i get that will work with the mach 460 setup? my front two speakers sound real bad with my new subs and i need new door speakers.
Old Jul 10, 2008 | 01:00 AM
aj552's Avatar
aj552
Default RE: door speakers with mach
these are what i got when 1st blew my stock ones.....works great
http://www.pioneerelectronics.com/PU...neer/TS-A6882R
cant go too high since that 460 amp isnt that great.....
Old Jul 10, 2008 | 01:05 AM
stallion11030
What do you mean you can't go to high? volume? I listen to my stero very loud so i will deff. need it be able to go high
Old Jul 10, 2008 | 01:25 AM
aj552's Avatar
aj552
ooo no with these speakers you can go as loud as you want lol
im saying i wouldnt go anything more than 50w rms, because you might under power them and blow them thats all
unless you slap on a amp
Old Jul 10, 2008 | 01:47 AM
ttocs's Avatar
ttocs
those speakers will only work if you have swapped out the deck and do some wiring. The factory woofe is a 5 x 7" 8 ohm woofer so a 4 ohm full range speaker will only hurt the factory amp. The closest factory replacement I know of is a 6.5" 4 ohm dual voice coil woofer at partsexpress.
Old Jul 10, 2008 | 10:14 PM
98LaserRedGT's Avatar
98LaserRedGT
I also have the Mach 460 system and are making some changes. Last year I put in http://clarion.com/us/en/products/20...385078991.html as my deck.
Now I ordered http://www.alpine-usa.com/US-en/prod...g=en&tab=F for the rear speakers. Is there anything special I have to do to keep from messing up the speakers and amps?
jerrytubes
Oct 23, 2015 12:11 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
