Box for two or three 12" subs?
Old Jul 21, 2008 | 02:43 PM
87chp's Avatar
87chp
Default Box for two or three 12" subs?
i have a 87 ssp/coupe. i was wondering if anyone makes a box fortwo or three12" subsfor this car. every box i've seen is too big. thanks
Old Jul 21, 2008 | 03:53 PM
mattlowe01's Avatar
mattlowe01
Default RE: Box for two or three 12" subs?
custom make your own
Old Jul 22, 2008 | 09:26 AM
GTRedfire03's Avatar
GTRedfire03
Custom build your own if you need something to fit in a small space.
Old Jul 31, 2008 | 09:40 PM
tkechris's Avatar
tkechris
In order for you woofers to sound good, they will need air space in the box. If the boxes your finding are to big, then you shouldnt be putting 3 woofers in your trunk. look up the specs of the woofer and find the minimum size they need to sound good. also, if you need to make a custom box (I had to do this), you can add polyfilm to inside of the box and it tricks the woofer into thinking that the box has upto 25% more space than it really does. I know it sounds weird but I've looked into it and it seems to work. this wont work with ported boxes though. Remember, Ported boxes will always be bigger than sealed boxes for the same woofer.
Old Aug 8, 2008 | 01:56 AM
mikemjohnson's Avatar
mikemjohnson
ORIGINAL: tkechris
+1. 2 subs with the appropriate box volume will sound better than 3 with inadequate (sp) volume
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
Sixer4Life
Sep 29, 2015 07:03 PM
cbird1177711
Sep 2, 2015 04:12 PM
