Stock Stereo + Subwoofer =???
Old Sep 1, 2008 | 08:24 PM
kingofqueenz's Avatar
kingofqueenz
the amp had power, the sub turned on, but i couldn't get an audio signal from splicing into the wires that were given in the tutorial
Old Sep 2, 2008 | 05:29 AM
ttocs's Avatar
ttocs
then try using a different audio source to drive the speakers. Turn the deck/amp on and use an mp3 player with a headphone to rca jack to feed a different source to it.
Old Sep 2, 2008 | 08:44 AM
GTRedfire03's Avatar
GTRedfire03
What year is your car kingofqueenz, the same year as the author of this thread(2000)? or is it newer?
Did you test the wires you tapped on to to make sure they were the speakers, b/c there are couple of the same color wires back there that arent speaker wires.
Tryed a different line out converter?
I have done tons of these cars like this and never had a problem with not getting audio.
Old Sep 5, 2008 | 12:51 PM
bigbadbert's Avatar
bigbadbert
Dear author,
Look for something called a PAC Trunk Loc. It allows you to use your rear speaker wires as a signal for your amp connections. Has remote/rca. You still have to ground and run the power wire though. I have the same headunit, and it works. Much cheaper than a new unit as well. It should cost you less than $40.
Old Sep 5, 2008 | 03:34 PM
MegaWatz's Avatar
MegaWatz
Originally Posted by bigbadbert
Dear author,
Thanks for putting this forum back on topic, ill search for it, can you send me a link of it if you have one? Thanks for the info bert.
Old Sep 5, 2008 | 10:00 PM
ttocs's Avatar
ttocs
I didn't know we still had a problem. The LOCs long name is a line-out-converter and I am willing to bet your amp has a section labeled "high level inputs" that may already do this. If you do not have the mach system then you can just tap the pos and neg wires at each of your rear speakers and run wire to the high level inputs(if available) or to your LOC.
Old Sep 8, 2008 | 10:01 PM
kingofqueenz
i don't think ill never get mine to work! I must have spliced into the wrong wires for the mach system
Old Sep 11, 2008 | 12:16 PM
bigbadbert's Avatar
bigbadbert
Nah I don't have a link. I picked mine up at a local audio shop. Just check around, I'm sure someone has them.
mungodrums
Sep 29, 2015 09:18 PM
vbonina
Sep 22, 2015 08:31 AM
ccdguy
Sep 19, 2015 05:20 PM
Ford_Dude
Sep 15, 2015 03:25 PM
TimeLord101
Sep 4, 2015 09:27 AM
