Radio install gone bad...
Old Aug 3, 2008 | 09:03 PM
sheriff's Avatar
sheriff
Default Radio install gone bad...
I have a 89 GT and cant get my aftermarket radio to work.. The speaker harness is there, but the other harness was cut out. I dont seem to have a constant power wire.( i've checked w/ test light i just have ignition power) no ground wire, there are 3 0r 4 other wires there 2 of which have ignition power, no constant power though....getting really frustrated can anyone please help.....also no factory amp in car if that matters....thanx
Old Aug 4, 2008 | 12:46 PM
ttocs's Avatar
ttocs
Default RE: Radio install gone bad...
Start simple, start with the fuses. Don't try and figure out if it is #5 or #6 just pull every single one and look at it, don't forget to look at the fuse box by the battery.
Old Aug 5, 2008 | 11:14 AM
GTRedfire03's Avatar
GTRedfire03
1988-89 Ford Mustang Stereo Wiring
Constant 12V+
Green/Yellow
Switched 12V+
Yellow/Black
Ground
Chassis
Illumination
Blue/Red
Dimmer
n/a
Antenna Trigger
Orange/Blue
Antenna
Right Front
Front Speakers
5 1/4"Doors
Left Front (+)
Orange/Green
Left Front (-)
Light Blue/White
Right Front (+)
White/Green
Right Front (-)
Green/Orange
Rear Speakers
5" x 7"Side Panels
Left Rear (+)
Pink/Green
Left Rear (-)
Pink/Blue
Right Rear (+)
Pink/Blue
Right Rear (-)
Green/Orange
See if this helps. Check your fuses. Worst case senario you may have to run your own power and just make your own ground.
Old Aug 5, 2008 | 12:14 PM
luckydawg003's Avatar
luckydawg003
If not, just go to the ignition harness and tap off the 12v constant wire...and run it to the radio. You can also tap off of one of the fuses if thats easier for you.
Old Aug 5, 2008 | 12:32 PM
GTRedfire03
ORIGINAL: luckydawg003
If you have to go to the ingition harness make sure you put an in line fuse on that wire.
Old Aug 7, 2008 | 09:12 AM
ttocs's Avatar
ttocs
the cig lighter is also a good place to find a constant, and yes a fuse is required.
mtgldr
Feb 3, 2024 09:00 PM
Gkid182
Sep 22, 2015 08:17 AM
unit91
Sep 15, 2015 09:53 AM
cbird1177711
Sep 3, 2015 08:43 PM
