Priceing?
Old Aug 16, 2008 | 09:57 PM
inukiller5's Avatar
inukiller5
Default Priceing?
ok... does anyone know how much someone would charge to take the mach 460 out, leaving the speakers, taking out the amps and deck.. and installing a new deck, and subs? i need an idea...please help
Old Aug 17, 2008 | 07:22 AM
SwishSkater's Avatar
SwishSkater
You could probably do it yourself, I've actually been looking into the very same thing myself. You need a specific harness for the mach 460 depending on your year, 99-03 is the same from my knowledge, and 04 is complicated, but metra has a harness for it. The price on a head unit is however much you decide to spend on one, find the perfect one and buy it. And subs, same thing. I wish you luck.
Subwoofer set up: http://www.mustangworld.com/ourpics/fcar/despeeds1.htm
SwishSkater
Old Aug 18, 2008 | 10:48 AM
ttocs's Avatar
ttocs
I show how to put a deck in the 460 in my cardomain page. How much you are charged will have more to do with where you are located, and the quality of work you want done. The 460 is not all that difficult, just a couple of funny numbers(woofer impedence) that you need to work around but it is not impossible and with a little tweeking the 460 can sound much better.
Old Aug 18, 2008 | 09:44 PM
inukiller5's Avatar
inukiller5
yeah i have thought about that... but i wanna get rid of the amp rack... i have took it out before... but i mean... i cant take out the speakers because the rear speakers have a weird connector. i mean to just get rid of the whole system and put a full aftermarket one in
Old Aug 19, 2008 | 09:06 AM
GTRedfire03's Avatar
GTRedfire03
That will be the best if you pull out the full mach system(new speakers, and deck). They do make a speaker harness that just plugs into the factory speaker harness so there is no splicing and makes it easlier.
Old Aug 20, 2008 | 06:11 PM
ttocs's Avatar
ttocs
you will be able to drive the stock tweets from your deck but the subs are 8 ohm and will need an amp run. It would be easier to replace the stock woofers and the deck/amps.
How much someone would charge will depend on where you are located, what side of town, how good a quality work you want done.
Old Aug 20, 2008 | 08:05 PM
inukiller5's Avatar
inukiller5
yeah. my question is that... where can i get that Harness? that way i dont have to rip any wires out.. and i really dont wanna splice the wires?
Old Aug 20, 2008 | 08:07 PM
inukiller5's Avatar
inukiller5
Because if i can get the harness... i can do it myself...my entire family does car stuff... so i mean thats no problem.. i have worked on Audio Systems before.. i just never messed with weird connecters that the Mach 460 Audio system has.. if i can get the adapter for that harness... then i am set
Old Aug 21, 2008 | 07:53 PM
ttocs's Avatar
ttocs
it really isn't rocket surgery, we can get you through it.
Around 02-03 they did a little change in the wiring of the mach system. You can get the hrns at any car audio shop, and most auto parts stores. If you could take a pic of the back of the factory radio, that will show us what hrns's you need and we can help to guide you. You could also take the radio out and go to a local shop and they could match it up. Be carefull that they don't try to sell you some bogus $50 hrns that you don't need.
Old Aug 21, 2008 | 08:42 PM
inukiller5's Avatar
inukiller5
could i get them from like craigslist or something... because there is no car audio shop around me but... Northside Electronics... and they are expensive as hell...like $40 for the wireing harness for a new aftermarket radio...
b8checker
Oct 8, 2015 12:55 PM
NYstang
Sep 30, 2015 09:56 PM
b8checker
Sep 30, 2015 07:11 AM
Drastang
Sep 30, 2015 03:48 AM
