Popping sound
Old Sep 29, 2008 | 04:36 PM
ttocs's Avatar
ttocs
it is as simple as soldering a 1k ohm resistor on the remote lead going to the factory amps. I say this because if you ever add an aftermarket amp you will need to give it the full 12v turn on. If this does happen all you will need to do is connect the new amps turn on to the decks turn on before the resistor and you can turn everything on...... Well I will not guarantee you can turn everything on, there will always be some guys will just not like you no matte what you do
Old Sep 30, 2008 | 07:14 AM
luvrbcs's Avatar
luvrbcs
Thanks. I like simple.
Old Oct 4, 2008 | 10:12 AM
the_camo_snake's Avatar
the_camo_snake
Yeah same here that helps alot. Thanks
cr620
Oct 3, 2022 10:18 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
KingRando
Oct 2, 2015 08:06 AM
MacSerio
Sep 27, 2015 01:05 PM
