subwoofer wiring
Old Oct 21, 2008 | 06:35 PM
symonds86's Avatar
symonds86
Default subwoofer wiring
i have gotten a set of 12 inch kicker square subs and i need to no how to wire them up as i got no diagram with them they have 2 pos and 2 neg terminals any help would be great
Old Oct 21, 2008 | 06:55 PM
disturbed471985's Avatar
disturbed471985
sounds great and very easy to answer but will need to know what ohm load u have dual 2ohm dual 4ohm its going to be either one unless u have reconed with aftermarket coils to a desired ohm. Should be labled on the box if not then stamped on the back of the sub either on magnet or post's.
Old Oct 21, 2008 | 09:01 PM
symonds86's Avatar
symonds86
sorry i meant to put it in the first post but they are 4 ohm
Old Oct 22, 2008 | 08:27 AM
PReal's Avatar
PReal
What amp do you have? Your options are 4 ohms in series parallel combo, or 1 ohm parallel. If your amp is not one ohm stable it will be quickly destroyed if you wire your subs that way.
Old Oct 22, 2008 | 06:49 PM
symonds86's Avatar
symonds86
the amp is a kicker NTX-2029 its 2 channel and says its 2 ohm stable thanks
Old Oct 23, 2008 | 08:08 AM
PReal's Avatar
PReal
Wire each sub in parallel. (positive to positive and negative to negative)
Run each sub in parallel off of one channel on your amp.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
cbird1177711
Sep 3, 2015 08:43 PM
