help with inline fuse
Old Dec 1, 2008 | 09:13 PM
Zach333's Avatar
Zach333
Default help with inline fuse
i bought light strip to put in my car and it's supposed to plug into your cigarette lighter to get the power but i wanted to cut that off and wire it to my fuse box or battery...
it had a positive and negative side fyi but i dont know how to wire in a inline fuse or what fuse thing to buy
can anyone help me out?
Old Dec 2, 2008 | 10:32 AM
devongarver's Avatar
devongarver
sure, go to an autoparts store, they sell inline fuse holders. A few bucks at most. Put the fuse as close to the source(fuse box) of power as possible. You can look in your owners manual for an empty or unused fuse or if it is a low current device(LEDs not NEON) you may use the radio/accessory fuse location. To do this you can either by a piggy back fuse tap(gay), or just strip 3/4 inch of the positive wire and wrap it around the blade of the fuse(doesnt matter which side since you are adding inline fuse) and stick it back in place. Works great. For the ground, use a crimp ring terminal and use the ground bolt at the fuse box. Hope this helps!
Old Dec 2, 2008 | 05:30 PM
ttocs's Avatar
ttocs
I would also suggest that you get a switch while you are at the autoparts store, agian a couple of bucks and easy to install. As cute as they are there will be a time when you will want to turn them off sooner or later(hopefully sooner).
Old Dec 2, 2008 | 06:21 PM
Zach333's Avatar
Zach333
well it did come with a whole control deck part but that would not stay put
i did it all today and there was no good spot to mount it on the drivers side
so i said screw it and took it all out lol there goes like 20 bucks
Old Dec 3, 2008 | 10:31 AM
ttocs's Avatar
ttocs
sell it to a friend and you will be better of with out it.
Old Dec 3, 2008 | 11:48 AM
Zach333's Avatar
Zach333
good idea
jwog666
Dec 27, 2021 08:09 PM
daytooday
Sep 20, 2015 10:55 AM
wenmill
Sep 11, 2015 07:07 AM
cbird1177711
Sep 2, 2015 04:12 PM
