06 GT firewall amp wire
Old Dec 15, 2008 | 03:11 PM
jahnplay's Avatar
jahnplay
Default 06 GT firewall amp wire
im trying to wire the power my amp from the battery to my amp which is in the truck so is there a whole in the firewall that i can put the wire through or i got to use the one behinde the wheel?? thanks
and can someone tell me where it is
Old Dec 15, 2008 | 10:10 PM
zed88's Avatar
zed88
The one behind the fenderwell and front right wheel is plenty big enough to accept 4 gauge, and is fairly easy to access once you remove the wheel. I did it myself in about an hour the other day.
Old Dec 15, 2008 | 11:04 PM
thedrod's Avatar
thedrod
I am using 0/1 gauge for my install I am doing right now. I just went to Home Depot and bought a 1 inch hole saw and some rubber grommets. Its simple and easy to do. If you are using 4 gauge I believe you can use the fenderwell grommet like stated by the above person.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
