Amp and Sub setup help
Old Jan 12, 2009 | 05:10 PM
bluestang23's Avatar
bluestang23
Default Amp and Sub setup help
I have an amp that works best at 2 ohms and I have 2 subs that are 4 ohms and are dual coil. Is there anyway i can wire the subs to be 2 ohms?
thanks
Old Jan 12, 2009 | 07:08 PM
ttocs's Avatar
ttocs
not 2 ohm mono. You can get 1 ohm or 4 ohm mono, and 2 ohm stereo, but not 2 ohms mono
Old Jan 13, 2009 | 07:34 PM
bluestang23
Thanks. Is there much of a sound quality difference between the 1 ohm and 4 ohm? I was planning on getting a new amp soon anyway but its about 300 for a 1 ohm amp that pushes 900 rsm and about $600 for a 4 ohm that does the same.
Old Jan 13, 2009 | 09:40 PM
flood41's Avatar
flood41
1 ohm produces louder bass than 4 ohm
Old Jan 13, 2009 | 09:42 PM
bluestang23
Or can I run 1 sub's coils in series then run it parallel to the other sub and run that sub's coils in parallel to make it 2 ohms? or would that **** it up?
Old Jan 14, 2009 | 12:31 AM
ttocs's Avatar
ttocs
1 ohm is no louder then 4 ohm, and is has no difference in sound quality either. The difference is the resistance that the amp will see, and dictate how much power the amp will send out. This is probably what he meant by it is louder as IF you had an amp that was 1 ohm mono stable it would probably send more power to the speakers.
hooking up one of the two coils will work just as well as hooking up half of your spark plugs. DON'T DO THAT, EITHER ONE........
You will either need to run one sub for a 2 ohm mono load, get a different amp or some different subs.
Old Jan 14, 2009 | 09:15 AM
flood41's Avatar
flood41
thank you for clarifying that. didn't have enough time to finish what i was trying to say
jwog666
Dec 27, 2021 08:09 PM
breaking
Oct 2, 2015 01:27 PM
fastbackford351
Oct 1, 2015 12:24 PM
guitarman376
Sep 30, 2015 05:54 PM
Drastang
Sep 29, 2015 03:31 PM
