What subs do i get?
Old Jun 7, 2005 | 12:10 AM
95stang5.0's Avatar
95stang5.0
Default What subs do i get?
What subs should i get fosgates?? I heard they are good i want the 10 inch becuase i have a box already. I would get them off bestbuy.com so what does everyone think also what amp should i get to run them. Probably 2 unless you think itd be better to run one sub and one amp and buy a differnt box. I want to spend around 4-5 and still have nice crisp bass that you can hear cooming
Old Jun 7, 2005 | 01:59 AM
KandyMan's Avatar
KandyMan
Default RE: What subs do i get?
10" alpine type "r" or if you can splurge...type "x"
Old Jun 8, 2005 | 02:11 AM
fastmustangs1's Avatar
fastmustangs1
Yea the Fogates are a good sub to go with!
Matt
Old Jun 8, 2005 | 06:06 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: 95stang5.0
Run a single sub with plenty of room. If you have the right enclosure dimensions and decent power running it, it can hit harder than 2 of them.
If you have the box already, then you need to figure out what the volume of the box is (hxwxd) Then compare that volume to the speakers spec sheet (QtS) of requirements for enclosures. The calculator below will help you with that.
http://www.carstereo.com/help/Articles.cfm?id=30
or
http://www.carstereo.com/help/Articles.cfm and choose the bandpass order of the enclosure you're using.
Old Jun 9, 2005 | 02:15 AM
CrzyHrsII05's Avatar
CrzyHrsII05
Personally i have owned FOSGATES, JL w0's, and JL w3's.... my 3's were AWESOME and i only powered them with 150 watt each (had two) would recommend them again... the fosgates were kinda cheepy ones but i dont know for somereason i just try to steer clear of fosgates, as directed by all my audio friends. if ur going with JL's people will try to talk u into w7's and the dual voice 6's but realistically unless ur doing competitions, in a car as small as a mustang u just need a w3. Get 10's if ur a rock/punk/etc... person(KICK DRUMS IS UR LOWEST NOTES) and get 12's if ur a rap/hiphop person (lots of lows not necissarily limited to drums). 10's give u pop and push, 12's give u resonance (spelling!?).
Old Jun 10, 2005 | 05:20 PM
01roushnj's Avatar
01roushnj
Personally for your budget i would get a 10" Alpine X-Type and run it with the Kenwwod KAC-810D amplifier. I had a 10" JL Audio W6 and it pounded the **** outta the sub. But thats just my opinion.
Old Jun 11, 2005 | 03:48 AM
Chanedeezy4106's Avatar
Chanedeezy4106
Did you mean the 801D MTX amp thats what I got pushing 3 MTX 10"s..It f**king bangs!!
Old Jun 11, 2005 | 09:42 AM
03GTType's Avatar
03GTType
If you trying to spend about 500. for a 10" sub and a amp I would suggest these..
Alpine 10" SWR-1042D and the Alpine 700W Class D amp MRP-M350
That is if your only going off of BestBuy.com that is...
Old Jun 13, 2005 | 09:57 PM
Military_man_88's Avatar
Military_man_88
MTX all the way...ooops you dont want to spend to much huh...the old fosgates where the **** but the new stuff is low end..all crap..you need to give more details on what you want out of it...bass quality what..
Sixer4Life
Sep 29, 2015 07:03 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
