Wiring Subs
Old Feb 14, 2009 | 01:17 AM
06z28eater's Avatar
06z28eater
Default Wiring Subs
I'm taking the subs out of my eclipse and putting them into my Lightning, I never ever drive the eclipse so I figured I'd put the system to use, I was wondering if anyone knew how I should wire it all up, I've searched for a few hours, cant get a great idea of what to do, but here is what I have....
Rockford Fosgate 401s 2 Channel 1200 watt amp
2 Rockford Fosgate HE2 10's
They are Dual 4 Ohm subs. I'd like to maximize this setup, they way it was hooked it inside the box in my eclipse was weird, i only hooked up 1 side of the amp to 1 sub, but the 2 subs were in no way connected, and the sub the amp was ran to was hooked up different than the other sub, when the guys installed that sub box a few years ago they said they would hook it up right.
I checked the subs, 1 of them did not even appear to be hooked up at all, and the sub that was hooked to the amp was hooked up as follows: - to - and then + and + to the amp. that was a weird wiring setup. Any help would be great, i have a few pictures ill add if someone can tell me which way to go with. thanks
Attached Thumbnails Wiring Subs-2_4ohm_dvc_4ohm.gif   Wiring Subs-2dvc_4-ohm_2ch.jpg   Wiring Subs-spk2dvc4.jpg   Wiring Subs-spk2dvcs.gif
Old Feb 15, 2009 | 11:40 AM
flood41's Avatar
flood41
if you want to bridge your amp wire your subs up at a 4 ohm load. if you want to run both channels wire each sub at a 2 ohm load.
Old Feb 15, 2009 | 08:54 PM
Bone32's Avatar
Bone32
Like he said.
You have the option of wiring it to 4ohm or to 2ohm. 2 ohm will be louder but you need to make sure your amp is stable at that impedance. It should be, but I would double check just to be sure.
Feel free to PM me with any questions. I used to work as an installer for circuit city and I have done both my cars and 6 or 7 of my friends cars.
Old Feb 15, 2009 | 09:53 PM
flood41's Avatar
flood41
Originally Posted by Bone32
Like he said.
wiring them at 2 ohms doesn't make them louder. it generally lets you put more power to the subs, but that is with a mono amp. a two channel has more power out put in a bridged mode at 4 ohms.
Old Feb 15, 2009 | 11:53 PM
ttocs's Avatar
ttocs
Like he said.
uh, what is circuit city? your an installer that has worked on 8 cars?
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
Sixer4Life
Sep 29, 2015 07:03 PM
