Sub and amp?
Old Apr 20, 2009 | 04:24 PM
mattsimonton's Avatar
mattsimonton
Default Sub and amp?
Hey guys,
I recently found a diy article on how to hook up an amp and sub to factory shaker 500 systems. But I know absolutely nothing about them. So I am asking to be pointed in the right direction
Music- I love metal with a lot of double bass so the kick has to be there.
I listen to alot of prog (dream theater, porcupine tree, etc...)
no rap or techno
budget- I dont want to be spending a crap ton of money on this.
Something that gives a good kick with out breaking the bank
Can you point me in the right direction?
Thanks Matt
Old Apr 20, 2009 | 04:34 PM
baddog671's Avatar
baddog671
If you don't want to waste any money, make sure you learn as much as you can and research everything before making a purchase. I'm just beginning a simple project of a sub, and cost is adding up real quick. It's the little things that you don't think of. Sure amp and sub cost a good bit, but you have to buy MDF board, cut it to the correct dimensions (saw,blades,etc.), assemble it (screws, powerdrill, wood glue, silicon), pad it and wrap it (poly mat, auto mat, snot spray), attach amp and sub in trunk (more screws), power it (power cable, ground cable, RCA cable, fuses, hardware), wire amp to sub (more wire, and of course these are all different gauge wires), etc etc
Old Apr 20, 2009 | 04:48 PM
WellG's Avatar
WellG
What do you guys think is the best model for a sub and amp? nobody wants to buy something like this and have it not be what they want....
Old Apr 20, 2009 | 05:46 PM
baddog671's Avatar
baddog671
I've bought Phoenix Gold parts in the past, they seem to be decent quality. That's what sub I'm installing now, and hopefully I can find another decent Phoenix Gold amp to match...
But that's just personal opinion...
Old Apr 20, 2009 | 05:53 PM
ttocs's Avatar
ttocs
if you are just wanting a simple add-on sub take a look at some simple amplified subwoofers that have the amp/sub/enclosure all in one. Infinity bass-link and SAS bazookas are systems that I have used and been happy with as simple add-ons but there are a number of different systems made that would work. This also takes the guess work out of getting the correct box, matching the sub and amps impedence, and normally gives you a remote bass controll so you can turn it up or down.
Old Apr 20, 2009 | 09:40 PM
mattsimonton
cool thanks for the info guys!
If I were to just add one sub I would need a 1 channel amp right? What is the difference in channels, etc?
Im looking for something around the 500 watt range, I think that will match the shaker pretty well, what do you think? Any set up reccomendations?
Thanks
Matt
Old Apr 20, 2009 | 09:41 PM
mattsimonton
woopsie- double post
breaking
Oct 2, 2015 01:27 PM
vbonina
Sep 22, 2015 08:31 AM
daytooday
Sep 20, 2015 10:55 AM
Art161
Sep 9, 2015 10:33 AM
cbird1177711
Sep 3, 2015 08:43 PM
