Factory Amp Remote Turn On
Old 04-28-2009, 11:39 AM
04AZUREBLUEMACH1
04AZUREBLUEMACH1's Avatar
Default Factory Amp Remote Turn On
Can I just use the factory amp remote turn-on wire instead of running new wire? It's pretty small, but it won't be pulling near enough current to warrant an upgrade, right?
I am running an MTX JH1200 (1200 WRMS) and MTX JH404 (200 WRMS).
Thanks!
04AZUREBLUEMACH1 is offline
Old 04-28-2009, 12:37 PM
ttocs
ttocs's Avatar
the remote turn on for an amplifier is a 12v, low current wire so you do not need anything bigger then a 16-18(thin)wire. The only problem that you will find is that ford is the only company to use a 5v remote turn on, again your amp needs a 12v. Rather then connecting to the remote turn on wire connect to an ignition wire and the amps will turn off with the key then, rather then the radio.
ttocs is offline
Old 04-28-2009, 12:41 PM
GTRedfire03
GTRedfire03's Avatar
Damn ttocs you beat me to it...... I just had to edit everything I said so I didnt double post the same stuff.
GTRedfire03 is offline
Old 04-28-2009, 12:46 PM
04AZUREBLUEMACH1
I have an aftermarket HU that supplies 12V, so no problems there.
I've currently got a resistor dispersing some of that so my Ford amps get 5v, but I'll take it out when I put my new amps in.
Old 04-28-2009, 01:01 PM
GTRedfire03
Oh so your redoing you whole system? Pulling out the mach and starting form new. Then yeah just use the amp turn on(blue/white) on the back of the aftermarket HU.
Old 04-28-2009, 01:33 PM
04AZUREBLUEMACH1
Thanks for the help. The search function on this site doesn't work very well, so I have one more question:
Is it fairly easy to modify the stock speaker locations to accept 6x9 speakers?
Old 04-28-2009, 01:48 PM
GTRedfire03
Dont know.....Why do you want a 6x9 anyways? I could see the back speakers being easy to modify to fit 6x9s but dont know about the fronts. I wouldnt recommend 6x9 anyways.
Get yourself some 6 1/2 components for the front.
Old 04-28-2009, 01:54 PM
04AZUREBLUEMACH1
Will I need an adapter to fit 6.5s into the 6x8/5x7 holes?
Old 04-28-2009, 02:00 PM
GTRedfire03
Yeah you will, scsoche makes something or you can make your own with some MDF.
Old 04-28-2009, 02:08 PM
04AZUREBLUEMACH1
Why would you recommend 6.5" over 6x8"? I understand that they are truly round, unlike the 6x8, but the 6x8 gives me more surface area and is also available as a component set.
Infinity Kappa 6.5" Components
http://www.infinitysystems.com/car/p...=US&Region=USA
Infinity Kappa 6x8" Components
Quick Reply: Factory Amp Remote Turn On
