Mach 460 Mess! Head Unit Help
Old Aug 3, 2009 | 08:05 AM
KYBLACKBULLITT's Avatar
KYBLACKBULLITT
Default Mach 460 Mess! Head Unit Help
First off, I have an 01 GT Bullitt with the Mach 460 system. I am installing a Pioneer head unit. When i got inside the dash, I found a mess of wires I wasn't prepared for. It has the two factory wiring harnesses, which Im guessing is normal. The smaller of the two, which Im guessing is the control for the factory amps?, has been spliced into and the harness is not plugged in to anything. Instead, they have some sort of rca adaptor hooked into the smaller harness. I played with this for a while, and I cant get the amps to come on at all. The speakers all work when I hook them up normally(as if there were no amps) with the 4 speaker wires. Do i just need to buy new wiring harnesses for my aftermarket? I need a simple wiring diagram for the two stock harnesses. Ive never wired something with the factory amps with this config.
Old Aug 3, 2009 | 10:50 PM
ttocs's Avatar
ttocs
check out page 2 of my cardomain page. Can you get pics of what you have?
Old Aug 4, 2009 | 07:35 AM
KYBLACKBULLITT
Ill try to get you a pic soon
GimpyHSHS
19
Dec 19, 2023 01:12 PM
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Drastang
Sep 30, 2015 03:48 AM
