H.I.D. Thread
Old Oct 12, 2009 | 08:38 PM
Retrosolutions's Avatar
Retrosolutions
Former Sponsor
Originally Posted by NuclearMuscle523
Ok, thank you.
This is an H1 kit in a projector headlight. Please just tell me what I need to buy from you. The ballast runs max current of 6A if that helps.
The projector lamps will complicate things a bit. Do you have it set up so the power to the ballast comes through to the outside of the housings?
Old Oct 12, 2009 | 09:19 PM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
Long story, before the projector came in I recieved the new HID kit, and noticed that it had male connectors as part of the assembly. I thought ahead and spliced the old headlight harness with a female on the power for the low beam, and left the high beam in the old harness along with the ground. The new projectors have four wires, power/ground for low, power/ground for high. So the old harness is giving power/ground to highs, and just ground to the lows. So pretty much the power to the harness is coming from the single wire I stole from the old harness. Does this make sense? The last kit I bought(from retrosolutions I believe) had a wire from the battery to a square box(relay) and the two kit were connected. I know, I was stupid. I just thought that with the H1 kit,(not the H13 like I previously had) needed some modification that I went ahead and did. I have the know how to hook up a relay, but maybe an all inclusive kit can save me time and headaches. I basically have to use the low beam power for the turn on for the relay, and run power from the battery, to the relay, out from the relay to the power for the harness. I just don't know the important numbers.
Old Oct 13, 2009 | 08:35 AM
Retrosolutions
Former Sponsor
Well,, I read this three times and I can only say that I'm a little confused still. Would you possibly beable to send a diagram to us via email? Just something made in MSpaint is fine even, just so I can see what's really going on here.
sales@retro-solutions.com
Old Oct 21, 2009 | 01:18 AM
Red ll iine GT's Avatar
Red ll iine GT
When it comes down to it..the only real HID kits that Ive been able to find that are hi los are Retrosolutions and HIDguy..both with good product and lifetime warranties..only difference I can find is Retro has bulb coating and 55 watt bulbs..does anyone have a stang hid comparison between 35 watt and 55 watt? Please post if you do.
jwog666
Dec 27, 2021 08:09 PM
Dokilar
15
Oct 16, 2015 08:13 PM
KingRando
Oct 2, 2015 08:06 AM
