Radio question
Old Dec 13, 2009 | 10:14 AM
roghoge's Avatar
roghoge
Default Radio question
I posted this in the 5.0 section then realized I probably should have posted it here.
I have a 95 5.0 mustang and last night while trying to install a new JVC HD Radio I let a wire touch another that shouldn't have when checking to see if I had installed it right and there was a big spark and now I do not have power to the dome light, clock, or radio (stock radio, buttons are the only parts that will light up not the display and the radio does not play). I went out this morning and checked all the fuses i could get out (there was one blue fuse i couldnt get out) and i replaced any that even looked like they could be blown and I still have no power. Is there anything else this could be? Or does it have to be a fuse and I just missed it?
Old Dec 14, 2009 | 08:24 AM
ttocs's Avatar
ttocs
did you really check EVERY fuse except the one? Did you look under the hood by the battery? I have noticed that it is not uncommon for the fuse to be blown to have no relation to the circuit in question when looking in the manual. because of this I say save time and just start in one corner of the box and work your way down till you check them all. It takes alot less time then getting the manual.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 30, 2015 03:48 AM
treesloth
Sep 28, 2015 07:03 AM
