Subwoofer Help
Old Jan 11, 2010 | 02:25 PM
H911STANG's Avatar
H911STANG
Default Subwoofer Help
hello all!
I'm brand new to this forum and looking for some technical help
i've recently just purchased a brand new 2010 mustang - grabber blue -
i also recently purchased a 15" kicker competition subwoofer with a 2000 watt legacy amp and a wiring kit. just wondering if somebody can direct me as to how to remove the radio surround/how to run wires and hook it all up?
Old Jan 11, 2010 | 06:11 PM
oldsch00lf00l's Avatar
oldsch00lf00l
Why not just tap a Line Output Converter off the rear deck speakers to run to the signal input of your amp? Other than that, you can find something that is keyed to the accessory/ignition in the fusebox so that your amp turns on and off with the key and run your power wire straight from the battery to your amp.
I think the fuses are called pigtail fuses and will allow you to replace an accessory/ignition on item in the fuse box and tie into the remote turn-on lead.
Old Jan 12, 2010 | 04:35 PM
H911STANG's Avatar
H911STANG
thanks old school!!
if i understood correctly, i should just be able to run a tap off of one of the rear speakers to the amp?
Old Jan 12, 2010 | 09:41 PM
oldsch00lf00l
If your amp has high level inputs, you would be able to do it. I always recommend a Line Output Converter to change the speaker level outputs from the factory deck to RCAs. There is a PAC unit that has a gain control that I like to use: http://www.sonicelectronix.com/item_...AC+SNI-35.html
Of course, I must take this opportunity to warn you that Legacy amplifiers are very hit or miss and their customer service department is generally less than helpful.
Old Jan 13, 2010 | 01:25 PM
H911STANG's Avatar
H911STANG
gotta make an edit on the subwoofer there old school. it's a Pyramid PB1617X 2000 Watt 4 Channel Bridgeable Mosfet Amplifier. and its got low level inputs. can you explain to me step by step how to%2
StupidTodd
Nov 8, 2005 03:18 AM
jnbishop
May 31, 2005 04:11 PM
link1235jeff
Mar 5, 2005 02:26 AM
bluthdr815
May 5, 2004 04:51 AM
