Old Oct 27, 2015, 10:31 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting
Print Wikipost
Halo Headlight Problem...PLEASE HELP!!!
Old Jan 26, 2010 | 03:58 PM
injen2nr's Avatar
injen2nr
Unhappy Halo Headlight Problem...PLEASE HELP!!!
Hey everyone. I perchased some new halo L.E.D projection headlights for my 2003 Mustang GT. I watched an online video on how to install the properly but something is wrong. My low beams work great but when I turn on my brights, the bolbs will turn on but glows very very dim. Also, my bright light icon on my gages stays on reguardless. Dim or bright.....it is still on..... Im in need of help badly. I dont know if it will pass for an inspection sticker in the state of Virginia with my bright lights being so dim...Please someone help me out.
Old Jan 26, 2010 | 06:55 PM
06z28eater's Avatar
06z28eater
thats weird man, i had the halo projectors on my 03 and they worked awesome. got some pics? maybe you should replace the bulbs, mine came with bulbs, maybe you have the wrong type of bulb for that housing? because im pretty sure its different than a stock bulb. more info on the lights please.
Old Jan 26, 2010 | 10:08 PM
injen2nr's Avatar
injen2nr
ok the bolbs that are in, are the ones that came with the kit. they were already in the housing. what i watched told me to splice in the power wires into the park lights....thats what i did...and the the other part just plugged in to the stock pluggins.....
Old Jan 26, 2010 | 10:14 PM
injen2nr's Avatar
injen2nr
the brand name of the lights is Zomkspeed
Old Jan 27, 2010 | 12:47 AM
06z28eater's Avatar
06z28eater
wait, you do mean you tied the halo black/white wires into the parking lights and not the actual bulb power wire right?
Old Jan 27, 2010 | 04:23 PM
injen2nr's Avatar
injen2nr
no i tied in my power wires in to the hot wires (park lights) and the black wires in the the ground wires......are there different wires that control the high beem?....im thinking that i got the same amount of power that go to my lows, flowing to my highs....but i dont know....the lights came with red and black wires, and wires that are in a plug that plugs in the the car.....are the parking light wires thatim using behind the plug that comes from the car?....im clueless...lol
Old Jan 28, 2010 | 09:51 PM
Sho_No_Go's Avatar
Sho_No_Go
Do you have a picture or a link to these lights? I wasnt able to find them. You should only splice your positive and ground wires for your LEDs/Halos to your parking lights. Then your High and low beam should be plug and play if I am reading this correctly. If you could poast a picture of the back of the lights or send me a link to where I can find info on these lights I am be able to help you out better.
Old Jan 28, 2010 | 10:54 PM
injen2nr's Avatar
injen2nr
for some strange reason o cannot find the healdights that i perchased....ill have to take a pic of them....but yeah the way you described to hook them up that is what i did....just my brights a WAY do dim to see anything
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
