AVIC Install - Do I hook up this wire?
Old Feb 24, 2010 | 02:52 PM
wbk_viper's Avatar
wbk_viper
Default AVIC Install - Do I hook up this wire?
I'm almost done with my AVIC X710BT install from a shaker 500. It seems to work just fine so far.
I used the PAC harness and made all the connections correctly I believe.
There is one wire I didn't hook up and I'm not sure if I was supposed to.
It's the system remote control wire. (blue and white if anyone cares)
If I am to hook that up where does it go? To the Amp turn on wire (also blue and white)? The only reason I didn't hook it up
is because the Amp turn on wire has a special connection on it as though its for an after market amplifier, which I do not have.
I'm just rolling the stock shaker 500 system. Since it works, I'm not sure if I needed it or not. I haven't tested it
thoroughly yet, maybe my subs wont kick in or something.
Thanks.
Old Feb 25, 2010 | 02:12 PM
Iskwezm's Avatar
Iskwezm
Your radio blue/white should go to the blue/white on the PAC unit to turn on the SHKER amp.
Old Feb 25, 2010 | 05:48 PM
wbk_viper's Avatar
wbk_viper
Thank you. All done with the install now that I hooked up that wire.. Piece of cake, took 5 hrs, but wasn't hard at all.
I think the AVIC HU definately sounds better than the Shaker HU. Lovin it.
Granatelli Sales
Jan 20, 2020 12:34 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
SYNY5TER
Sep 2, 2015 01:35 AM
