Antenna
Old Mar 11, 2010 | 01:26 PM
compdude97's Avatar
compdude97
Default Antenna
I want to get rid of the radio antenna on my stang and replace it with a windshield mounted unit. I listen to a lot of AM radio what would be a good unit to get?
Old Mar 15, 2010 | 01:35 PM
ttocs's Avatar
ttocs
if you listen to alot of am then I would recomend the factory antenna. AM stations are hard to get to work correctly with out a nearly perfect antenna. I would not switch antenna with out expecting to loose some reception and that little bit of loss on am can mean everything.......
Old Mar 17, 2010 | 01:55 PM
compdude97's Avatar
compdude97
I can't picture a decent powered antenna would be worse than the factory antenna, I mean AM reception is already pretty crappy in these cars.
Old Mar 21, 2010 | 11:17 PM
ttocs's Avatar
ttocs
antennas are funny things. While signals do pass through glass/metal and almost everything part of the signal is lost. As you mentioned am signals are generally pretty weak alread so even a little bit of loss could be big deal. The amplified antennas I have worked with(more then a few) in the automotive arena have never impressed me. You can't amplify what is lost..........
Old Mar 26, 2010 | 07:55 AM
compdude97's Avatar
compdude97
What if I was to get one of those hide away antenna's and put it near the grill opening?
kevsgt
Oct 9, 2015 10:12 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
movielover40
Sep 15, 2015 10:37 AM
cbird1177711
Sep 3, 2015 08:43 PM
