Door Speakers '09 GT
Old Apr 29, 2010 | 08:19 PM
SON OF 68's Avatar
SON OF 68
Default Door Speakers '09 GT
Has anyone done 6.5 components in the doors and still left the 8" in place? Or is 5.25 all I'll get away with?
Old May 4, 2010 | 09:55 PM
dw32005's Avatar
dw32005
you can do the 6x8's to thats what i threw in my doors.
Old May 5, 2010 | 12:12 AM
oldsch00lf00l's Avatar
oldsch00lf00l
You can do components AND leave the Shaker 8's. The only downside is finding a place to stick the tweeters. I was also told that the Image Dynamics 5x7 convertible component set sounds quite nice in Ford/Mazda vehicles, but I have yet to hear them.
Old May 5, 2010 | 12:46 PM
SON OF 68's Avatar
SON OF 68
Sounds good, thanks. I have always liked and had great sound from the JL components. Although I haven't used an 8" in the past. So I was kinda thinking a set of 5.25 components and then using the 8" maybe a set of kickers for a mid bass driver. I have an older set of really nice kicker mr 100 crossovers that should work well for 8" mids.
Old May 5, 2010 | 09:56 PM
oldsch00lf00l
Keep in mind, this isn't my install, but I was thinking along these lines in the beginning:
Relocate that power mirror controller then build the sails to house the tweeters.
This is what I ended up doing instead:
Looks stock, but I am using a 4" full range driver in the 6x8 location and a Mach5 Audio MLI-65 in the 8" location via some Target cutting board baffle rings:
Old May 6, 2010 | 08:44 AM
SON OF 68's Avatar
SON OF 68
Nice. I like the tweeter idea. Still kept a very factory look relocating the mirror switch.
Old May 6, 2010 | 04:55 PM
pentavolvo's Avatar
pentavolvo
how did u get the grill to seperate from oem woofer
Old May 7, 2010 | 12:35 AM
oldsch00lf00l
First I tried freezing a sub overnight, thinking that would make the adhesive brittle and lift easily. Well, that didn't work out so well.
Afterward, I carefully used a heat gun and a screwdriver to pry the grill loose. The only downside to using the heat gun was that part of the subwoofer surround lifted from the basket. In my case, that was a moot point because one of my door subs had a bad voice coil from the prior owner of the car.
jerrytubes
Oct 23, 2015 12:11 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
