WTF! I miss the Skipper500
Old May 7, 2010 | 05:38 PM
bluovalguy's Avatar
bluovalguy
Default WTF! I miss the Skipper500
Today I got pissed at the Skipper and decided to go to Car Toys and replace it. I didnt wanna spend a ton, so I got this one (still ended up spending $350).....
http://www.kenwoodusa.com/Car_Entert...ver/KDC-MP345U
Now the stereo sounds like complete ***. The skipper sounded 10 times better. The installer at car toys says he cant hear a difference. I think he has hearing damage.
The music cuts in and out, there is either no bass or way to much bass, and the music sounds hollow. It almost sounds like a radio in a room with no carpet or furniture, it just kinda echos. Dont really know how to describe it, but it is not right.
The deck is the only thing changed, so what gives? Is that just a POS deck or did they install something wrong?
Old May 7, 2010 | 05:59 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Sounds like he reverse wired the + and - on the speakers. Hollowness and lack of bass is a symptom of this.
Old May 7, 2010 | 06:13 PM
oldsch00lf00l's Avatar
oldsch00lf00l
If the bass changes drastically when you fade from front to rear or move the balance from left to right, chances are something is wired out of phase.
Old May 7, 2010 | 06:19 PM
bluovalguy's Avatar
bluovalguy
I'm stereo stupid, so bear with me. Are the lower door speakers supposed to fade in and out with the balance or do they stay on all the time cuz they are mini subs? When I change the L R balance, the lower door speakers still have bass. They dont turn off. If they are supposed to go off when you adjust the balance between the left and right side, then I know they wired it wrong.
Oh, and thanks for the help!
Old May 9, 2010 | 09:11 AM
pentavolvo's Avatar
pentavolvo
what wiring harness did he use
there is no way it should sound worse if wired correctly
Old May 9, 2010 | 10:38 AM
ttocs's Avatar
ttocs
are the factory woofers playing at all?
Old May 9, 2010 | 10:51 AM
bluovalguy's Avatar
bluovalguy
They used a harness that works for an f150 too. They said it is the same.
You mean the woofers in the door? Yes, they stay on all the time.
Old May 11, 2010 | 02:53 AM
ttocs's Avatar
ttocs
ok great, so the bass just sounds as though it is not as strong right? Do you happen to know if they used the rca outputs on the deck? Does it have a subwoofer control that you probably have turned up real high?
Old May 11, 2010 | 03:14 AM
bluovalguy's Avatar
bluovalguy
Not sure what they did, but I took it back this morning and had a different installer yank it out and check it. He said it was wired wrong. He redid and it sounds great now.
Now I am regretting getting such a cheap deck. Think I am gonna go back tomorrow and get the next model up. They have a 14 day return policy, so it shouldnt be a problem.
Thanks for all the help!
Old May 11, 2010 | 09:02 AM
2005Redfire6's Avatar
2005Redfire6
Should have gotten a double din! I paid $300 for mine with my friends Best Buy discount...
https://mustangforums.com/forum/v6-s...er-3100-a.html
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
