More Mach Problems...
Old Aug 4, 2005 | 01:32 AM
hawaiian7873's Avatar
hawaiian7873
Default More Mach Problems...
I just finished installing the infinity kappa speakers on my Mach 460 system. The speakers work great until I start the engine...then they they "pop" and the amp will shut-off and reset. If anyone has a clue what is causing this it would help me a lot. Mahalo
Old Aug 4, 2005 | 04:56 AM
87FiveO's Avatar
87FiveO
Default RE: More Mach Problems...
sounds like you have speaker terminals hitting metal which is grounding the system out and putting everything into protection mode. Recheck your speakers and reset the car undo the battery for a few min
Old Aug 4, 2005 | 12:58 PM
hawaiian7873
i doubt thats the problem because the system works fine when the engine is not running. Its only after i start the engine, i get problems.
Old Aug 4, 2005 | 09:21 PM
Kidrosey's Avatar
Kidrosey
could your alternator be overcharging? Unlikely but possible
Old Aug 31, 2005 | 11:17 PM
LazrRd00GT's Avatar
LazrRd00GT
Its a possibility that you may have a bad ground connection and/or The speakers cant handle the mach 460's lower resistance: Mach 460 is rated at 2 ohms and most aftermarket speakers are rated at four ohms. The mach 460 speakers are dual voice coil speakers and they were wired at 2 ohms resistance. So unless you find a 2 ohm speaker or replace the originals, that "pop" may never go away or have an affordable fix.
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
