Help - Factory stereo draining battery
Old 08-31-2010, 08:11 PM
jj06v6mustang
jj06v6mustang's Avatar
Default Help - Factory stereo draining battery
Thanks in advance for any and all help....
My wife drives a 2006 Mustang v6. It is equiped with the factory shaker 500 stereo system. Recently we have been having problems with the battery going dead. I put an amp meter in line with the negative terminal and battery cable and started pulling fuses. I have a 1.5 - 1.8 amp draw with everything turned off and all doors closed. When I pull the stereo fuse in the engine compartment the draw goes away. I know the stereo draws a small amount of power to hold presets and such, but 1.5 amps seem way too high. Any sugestions????
Joe
jj06v6mustang is offline
Old 09-01-2010, 09:10 PM
charliebrown266
charliebrown266's Avatar
yes 1.5 amp draw will kill a battery over night! It should be around a 100milli amps.there maybe a problem with the deck not turning off,i remember reading something about this.Have you tried turning the radio off,before turning the car off?
charliebrown266 is offline
Old 09-06-2010, 10:37 AM
TPony
TPony's Avatar
Joe, very common with 05-07 mustangs. I still have my original battery, but i place it on a tender overnight.
TPony is offline
Old 10-09-2011, 05:39 PM
pony07amk
pony07amk's Avatar
Default Same here
Joe
I have a 07 that just started to act up. A little history. I had a coolant leak and it was blowing in to the engine compartment. I replaced the degas bottle. Shaker 500 died. Battery started to die. ( 2 days in garage it was dead) After jump and full charge the battery was at 750 CCA. I have read many threads on this issue. My problem may be that coolant got inside the alternater and screwed this up. I am going to do a test to it and see. I like you are not a very happy pony owner. Let me know if you have any other issues.
pony07amk is offline
Old 10-09-2011, 06:11 PM
wayne613
wayne613's Avatar
Actually it should be half that(page 15 of that link, <=50milliamps) or below.
You'll have to replace the head-unit. Since it's out of warranty I'd just go with a cheaper pioneer double-din dvd unit myself. Get more from it, sound better, and won't kill your battery.
wayne613 is offline
Old 10-10-2011, 03:51 PM
pony07amk
pony07amk's Avatar
DO YOU THINK THE SHAKER 5OO KILLED THE BATTERY. I PULLED THE FUSE TODAY AND JUPMED IT, DROVE APPROX. 1 HOUR. WE WILL SEE IF THIS DID THE TRICK
Old 10-10-2011, 04:31 PM
wayne613
wayne613's Avatar
I can't say for certain. You'd have to use the diagnostic/testing procedure in that service link I posted previously to know for sure.
wayne613 is offline
BOB ROME
07-26-2023 01:54 PM
4cylinderplus2
10-09-2020 07:45 PM
jerrytubes
10-23-2015 12:11 PM
jrrhd73must
10-02-2015 09:17 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Help - Factory stereo draining battery
