Replacing Door Speakers in a New Edge?
What all is involved in the process? I'm a noob to audio.
What is the size of the speakers in the doors? 6x8 or 6x9?
Will I have to take off the entire door panel?
Once I'm in there, what all is involved as far as wiring?
And lastly, what are some good options out there for the speakers?
i dont remember the size off the top of my head but yes the door panel must come off. use a screw driver to CAREFULLY pry out the window switch panel from the relief opening in the top, there will be 2 screws back there you remove and then a few of those push in plastic clips around the edges of the door panel, after removing that stuff you must pull the panel up far enough to get the upper lip free of the top of the door and then pull the top edge in twords the seat. making sure to remove the wires that are connected. if you have premium sound you must remove the cover for the upper speakers and then take out he screw holding it in place first.
for the speakers your going to need to set your price levels, keeping factoy head unit? factory amp< upgrading one of both? how much do you have to spend?
