Problem with HID's i just bought
Old Oct 20, 2010 | 10:45 AM
longlive289s's Avatar
longlive289s
Default Problem with HID's i just bought
Just bought these http://www.hidnation.com/9007hidkits.html
plugged the ballast in and the 9007 plugs just fine into the power plug. Turned the lights on and the bulb turns on but it is really. much dimmer than stock. They are suppose to be 8000k and these are almost yellow. if you hold the brights on, they do not turn on and the low beam stays on. If you turn the brights on (not holding the switch) the low beam turns off and brights still dont turn on. Tried the other bulb and ballast and same thing.
ideas? thanks
Diode Dynamics
28
May 26, 2022 12:02 PM
soulcaliber39
Dec 28, 2016 04:57 AM
mustangfan305
Aug 31, 2015 07:18 AM
inyadreems
Aug 21, 2015 09:10 AM
