CD deck doesn't remember programmed stations
Old Aug 18, 2005 | 10:49 PM
taco's Avatar
taco
Default CD deck doesn't remember programmed stations
I have a sony xplod CD deck in my 89 LX and every time I turn on the car, it spits the CD out and also doesn't remember any of the programmed stations that I put in. When I bought the car it was doing this. Any suggestions on what it could be would be great. Thanks in advance
Old Aug 19, 2005 | 12:29 AM
Shawn02GT's Avatar
Shawn02GT
Default RE: CD deck doesn't remember programmed stations
sounds like the 12v constant has a short or isn't hooked up at all.
Old Aug 19, 2005 | 04:10 AM
taco's Avatar
taco
I'll try and check that out soon. Thanks for the reply.
Old Aug 19, 2005 | 08:47 PM
87FiveO's Avatar
87FiveO
he got it, that would be a constant problem aka memory....check the fuse and yellow wire
Old Dec 29, 2006 | 02:20 PM
jrt1990's Avatar
jrt1990
(sorry for bringing up an old thread but I had to search to find this) so how exactly do you wire the memory cable because if I don't have my memory cable hooked up the way it says, it doesn't remember anything and shuts off correctly when I shut off the car but when I do hook it up, the stereo does remember stuff but doesn't shut off with the key... Whats the deal?
Old Dec 29, 2006 | 02:46 PM
NvRdoNeStAnGsIx's Avatar
NvRdoNeStAnGsIx
An easy trick to wire the 12v power source is run a wire from the head unit's specified connecter for the 12v, under your dash, to your fuse box. Plug the wire into your Horn fuse.
Since the horn will work with the car on or off, it is a constant power source.
Old Dec 29, 2006 | 05:29 PM
jrt1990's Avatar
jrt1990
Doesanyone have a diagram of how to wire up the power to the head unit?
Old Dec 29, 2006 | 08:38 PM
jrt1990's Avatar
jrt1990
Nevermind. I seemed to have figured it out.
baddog671
Jul 26, 2016 01:20 PM
kevsgt
Oct 9, 2015 10:12 PM
Dathan
Oct 5, 2015 05:52 AM
algregory
Sep 11, 2015 11:44 AM
zachary1988
Sep 4, 2015 03:04 PM
