S197 Stereo Screw Help
Old Jan 20, 2011 | 07:45 PM
ccwebb's Avatar
ccwebb
Default S197 Stereo Screw Help
I recently purchased a radio delete plate to replace the factory stereo head unit. There are four 7mm flanged hex head screws that secure the head unit and these screws are reused to secure the delete plate.
I have been trying to find the part number for these screws to no avail. I've even located the Ford manual illustration of the stereo system as well as the instrument panel and it shows everything EXCEPT the screws.
Also, the plate came with spacers for the lower two screws that tilt the plate outwards at the proper angle to make it flush with the surrounding Lower Trim panel. Of course the factory screws are too short to be threaded through the spacers and still engage the threading where they mount. Ultimately I'll need longer versions of these screws but tough to determine thread pitch in order to get aftermarket screws.
Does anyone know the part number for the factory screws or where I can source aftermarket screws that would do the trick?
Any help with specs, part numbers etc. for these lil buggers would be greatly appreciated.
Thanks!
jwog666
Dec 27, 2021 08:09 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
