Install Components?
Old Jan 23, 2011 | 08:53 PM
  #31
HT's Avatar
HT
Bingo. That is what I needed. Thanks for that info. I have a much better understanding now. I'll be able to envision it a bit better when I have the PAC unit in my possession as well.
The part that I wasn't getting was that when done, there will be a set of wires (the ones soldered together) with a harness on each end. I didn't understand that, but now I see that the PAC end goes into the stock harness, and the Pioneer end goes into the head unit. Makes sense.
Old Jan 23, 2011 | 09:08 PM
  #32
HT's Avatar
HT
The picture of the PAC unit on the PAC site looks a bit different from the units that I see for sale on every retail site? Could someone link me to the exact product that I need?
Old Jan 25, 2011 | 11:35 AM
  #33
wayne613's Avatar
wayne613
Right here, and right here. The box housing is just colored differently/newer release from the one listed at crutchfield. Both are the exact same thing, although likely ordering newer stock will get you a higher revision of the product. So long as it's a PAC "C2R-FRD1", your good.
Just hit crutchfield's "outfit my car" section to make sure, and select the installation portion. There's really only 2 for FORD's for actual radio replacement that I'm aware of. The other(MS-FRD1) is for the newer models with SYNC and no double-din opening for mounting.
mtgldr
Feb 3, 2024 09:00 PM
Sep 10, 2015 08:39 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
