Running two amps.....
Old Jan 26, 2011 | 12:16 PM
oldsch00lf00l's Avatar
oldsch00lf00l
Originally Posted by wayne613
Itīs something in the realm of 85amps for the 05-09īs. Iīd hit up google for the output of the 11īs (or maybe someone can chime in here), likely higher, but I still doubt itīd be able to keep up.
If you can find someone local itīs usually not very expensive to have your existing one rebuilt to output quite a bit more.
You sure about that? The MOTORCRAFT Part # GLV8424RM is rated for 130 amps and the MOTORCRAFT Part # GL977RM is rated for 135 in the GTs. Even the MOTORCRAFT Part # GL905 for the V6s is rated at 135 amps.
Old Jan 26, 2011 | 12:24 PM
wayne613's Avatar
wayne613
TBH, no, this is what I've seen stated here for the 05-09's for their base output. Are those numbers not their max rating though, essentially with RPM's greater than 1500?
All I really know for sure is with my current setup, rather modest in comparison to most, it comes up quite short. So it might be doing 135. I know the aftermarkets tend to only go as far as 200 from the few I looked up. Wish I had an ammeter to connect to see what the stock draw is.
Old Jan 26, 2011 | 12:58 PM
oldsch00lf00l
The OEM Motorcraft alternators may be rated at max RPM, so who knows.
What I do know is that my 2006 GT has done well with an aftermarket sound system that has a combined fusing of 160 amps. My Lunar L450, a class ab amplifier, has a 70 amp fuse and my Clarion DPX1851, a class gh amplifier, has a 90 amp fuse.
My next iteration of the sound system may have as much as 250 amps of class AB fusing. As a result I am looking into the 270 amp Mechman alternator for the 2006 Mustang Gt.
Old Jan 26, 2011 | 03:05 PM
wayne613's Avatar
wayne613
That one has 155 amps @ 800 rpm if it's indeed the same one I'm looking at. Very nice. If I could find one for under $200 later...yeah, probably won't happen.
My battery pool can take it as I upgraded that, but longevity wise I have to to shell out a $100 a year for a new battery as mine don't last with just this extra 40-50amp draw tacked on between computer and amp. Of course that is excluding the 4 shaker subs and amps. Stock still.
Old Jan 26, 2011 | 08:48 PM
AudioNutz's Avatar
AudioNutz
So I'm not really sure how this thread was twisted to the subject of alternators, but I'll answer your questions that were directed to me.
Originally Posted by 240dbio
Ok from what I'm understanding. I have a750w amp and a 240 watt amp. So I would need a thicker cable to run from the battery to a distributor.
Correct. That thing is called a "Distribution Block".
And from the distributor I could run say an 8 to the 240watt and a 4 to the 750? or would I need a bigger one for the 750 watt amp.
If it's a short length from the distribution block to the amplifier, then yes, it is acceptable to use the smaller gauge cable. Keep it 12-18 inches, and you may be ok.
Remember: Ground cable sizes MUST be at least as large as the positive power cable. Current flows from negative to positive.
Preouts
I have a preout on one amp (speaker) can i put that preout to input (by RCA) to my sub amp?
I'm still not sure I understand. If the 1st amplifier has RCA inputs, as well as a pair of RCA outputs, then yes, it's ok to use that to feed the subwoofer amp from those outputs.
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
