Strange Problem...
Old Aug 6, 2011 | 12:19 PM
awillquik's Avatar
awillquik
Default Strange Problem...
EDIT: This didn't end up being a real "problem" (not that anyone will read this).
Old Aug 6, 2011 | 12:42 PM
kput's Avatar
kput
Get your battery checked.
You're running amps, so you're drawing more power, which would explain why you don't have the problem when you don't run the radio.
Kinda like how if you sit in your car for an hour with the radio, ac, and ignition on but without the engine running it will drain your battery?
I'm guessing that's your problem.
Your battery probably needs replacing/charging.
Old Aug 8, 2011 | 01:14 AM
ttocs's Avatar
ttocs
sounds like yer deck took a dump to me.
Old Aug 30, 2011 | 09:42 AM
hotrod351's Avatar
hotrod351
well you said when you first installed it and turned it on there was a pop noise, that should of told you something wasnt right.
Old Aug 30, 2011 | 11:46 PM
ttocs's Avatar
ttocs
the mach are known to do this. The stock remote turn on is 6v and aftermarket decks are 12v. There is a topic in section sticky that explains one way to do it or just put a 1.5k resistor inline on the remote wire.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MustangVixenGT
Sep 16, 2015 04:16 PM
Emblazoned
Sep 3, 2015 10:45 PM
