Wiring my amp??
Old Sep 12, 2005 | 11:31 PM
v6stang1335's Avatar
v6stang1335
Default RE: Wiring my amp??
Haha sorry for that little outbreak i have a problem with that sumtimes
i can bridge it to a mono output and 2 channels but is there any way i can use the full power of my amp cuz my amp puts out 800 x 2 at 4ohm bridged max and my subs are 4 ohm 1000max 500rms .... with a 1 mono out put for both and two unused channels that wouldn't be powering the subs much would it? sorry again
Old Sep 13, 2005 | 12:09 AM
v6stang1335
One more thing my amp says in bridged it can handle 4~8 ohms does that mean it can handle all the way up to 8 ohms?
Old Sep 13, 2005 | 12:45 AM
bryanec's Avatar
bryanec
If you bridge those subs you will have 2 ohm load. It might overheat the amp and it will cutout. The ohm rating is usually meant for the lowside, any amp can run a higher impedence (8 ohm), most good sub amps can handle lower than 1 ohm.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
