Help with wiring aftermarket HU
#21
Im not sure if your aware or not but you also need to run a separate wire for your ign wire for the head unit,2008 and up use the can bus so you need to use a ad a circuit in your fuse box,just look at your fuse box diagram and piggyback it to a delayed power circuit so that way it will be like stock and the head unit will stay on after you turn your car off until you open the door.
jwog666
12-27-2021 08:09 PM
09-24-2015 09:18 PM
