Disable the cigarette lighter socket when closing machine
Old May 15, 2015 | 03:21 PM
iMuscleMan's Avatar
iMuscleMan
Default Disable the cigarette lighter socket when closing machine
I want to connect the device to the cigarette lighter socket, which needs to be switched off when closing the machine. How can I do it?
Old May 15, 2015 | 09:47 PM
tbar's Avatar
tbar
You could splice a switch into the power wire going to the accessory plug. You might also be able to run the power wire from the accessory plug to ignition switched power.
Old May 16, 2015 | 06:18 AM
DRAGUL's Avatar
DRAGUL
Install a relay and connect the coil to switched power.
Old May 20, 2015 | 09:11 AM
eagle42101's Avatar
eagle42101
+1 on what DRAGUL said.
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
kevsgt
Oct 9, 2015 10:12 PM
