Help with backup camera on on s197 with Kenwood HU
So I got bored today and picked up a rear camera. Tapped reverse light and ground to the camera. Plugged video cable to HU. And ran the HU purple reverse camera wire to power cable from rear reverse light. Here's the problem: Camera only turns on if I manually turn it on (hold Nav button for 2 seconds). How can I get my HU to switch to rear camera automatically?
thanks guys
thanks guys
My best guess is that there is a setting in the kenwood that will turn it on automatically. I have only used pioneer and the two I have had have automatically turned on when I went into reverse. Also it might be a separate connection at the back of the head unit that you have to make. I think the reverse lights can be the actual signal so either run a wire from there, or run a wire from a different part of the wiring harness to make it work. some newer cars don't need to run a wire from the reverse light, that is because there is already a signal from the car's wiring harness going to the factory radio, you might just need to tap into that. sorry I can't be more help.
would you mind posting a few pics of how you mounted the camera and all for someone who is considering doing the same type of upgrade??
I'd appreciate it. I haven't picked out a head unit, but am starting to look and wonder if I want to go ahead and possibly upgrade the HU and add a camera while I'm at it.
Thanks either way...
andretti
andretti
thanks guys
thanks guys
backup camera
thanks guys
thanks guys
http://www.vardsafe.com/
09-18-2015 12:25 PM
