Shaker 1000 trunk sub question
Old Jan 7, 2021 | 02:58 PM
07ua's Avatar
07ua
Default Shaker 1000 trunk sub question
have a 2007 that was stock with the shaker 500 system door subs were blown so i replaced them with the shelby kicker replacements and replaced the stock amps with aftermarket and the head unit with aftermarket as well.
i recently picked up the shaker 1000 trunk sub along with the 4 amps
soooo my question is can i hook up the stock amps and sub box to my aftermarket head unit with rca sub outs?and if not is there a direct replacement for the 10"subs single voice coil that i can then just use an aftermarket amp
thanks for the help
i know there is info that says to get the harness adapter to run the factory amps but since i have two aftermarket amps running my door subs im not sure how i can hook the head unit to the factory sub amp in the trunk....
cthomastk
Oct 15, 2019 05:37 PM
monovitae
Feb 12, 2013 04:24 PM
etnoats
Apr 8, 2010 05:09 PM
dheller1
Jan 23, 2009 12:21 AM
Triple T
Sep 18, 2006 09:12 AM
