Amplifier help!!!
Old Nov 17, 2005 | 04:42 AM
Allstar's Avatar
Allstar
Default Amplifier help!!!
ok i have 2 10"MTX subs installed in my car, i just hooked up the amp, red pos wire to the fuse to the battery, blue remote turn on wire to the turn on wire behind the deck, and the black ground wire grounded to the frame, the amp is getting power because the red light is on and the subs are on but very low, i fiddled with the settings... nothing seems to make it louder, i dont kno if its running off my deck or not but it shouldn't be because its hooked up right to the battery, can some help me or tell me what to look for?
Old Nov 17, 2005 | 10:39 AM
tripsevn7's Avatar
tripsevn7
Moderating with Angels
Default RE: Amplifier help!!!
little more info bro, do you have a multi reader? sounds like you arent getting voltage, what size fuse do you have on the power wire ?
Old Nov 17, 2005 | 12:10 PM
Hisss04Cobra's Avatar
Hisss04Cobra
says hiththth
Is something wrong with the amp?
Old Nov 17, 2005 | 01:29 PM
dconder's Avatar
dconder
What kind of amp is it? I have seen some amps that the led light is suppose to be green. If it is red, that means there is a problem with current or load or something.
Old Nov 17, 2005 | 02:28 PM
Allstar's Avatar
Allstar
its a kingwood, i think they use them in mercedes cars, im not sure what size the fuse is how can i check? and i have it hooked up to a dual deck, its hooked up to the remote line properly, is there some kinda button i have to hit to give it the juice? or does it just do it automatically when i turn the head unit on?
Old Nov 17, 2005 | 03:00 PM
dconder's Avatar
dconder
Do you have a model number? One of the amps I found searching for Kingwood has multiple lights for power and protection.
Old Nov 17, 2005 | 04:24 PM
tripsevn7's Avatar
tripsevn7
i take it you dont have a multi reader do you?
Old Nov 17, 2005 | 04:59 PM
Allstar's Avatar
Allstar
i have a multi reader i think, has the dc, ac etc. ok i think i found the prob. i have it hooked up to low input at the moment, i need it to be hooked up to high input.. although im a little confused im gunna post some pics the directions that came with it are extremely confusing and make no sense lol, basically im asking, how do i hook up high input?
Old Nov 17, 2005 | 05:00 PM
Allstar's Avatar
Allstar
sorry for all the posts but the pics are big
Allstar's Avatar
Allstar
i'll go check the model of it in a min
