AMP
Old Dec 6, 2005 | 03:48 PM
  #31
techmanBDsStang's Avatar
techmanBDsStang
Default RE: AMP
Bigwille, about the first problem. You say the speakers don't sound great? Did you install it? or did a professional? either way, I would check that the correct polarity on all the speakers were done right. If any of them are reversed, they will sound like crap.
Old Dec 6, 2005 | 04:02 PM
  #32
pj1010's Avatar
pj1010
Default RE: AMP
ORIGINAL: techmanBDsStang
ORIGINAL: pj1010
I don't consider a S/N ration of below 81 dB "great." In fact, it is terrible. 1% THD - probably one of the worst 4 channel amps I've seen. I believe my last amp was 200x4 at .002% distortion and 115 dB.
The kicker there is the distrotion level...1% is HUGE. I would not recommend that amplifier...at all.
OK you 115 db Signal to Noise ratio means nothing without what power is was rated at.
It isn't 1% it is < 1%. Any THDN that is <1% is not audible to the ear.
so what amp was it? what rated power was it tested at for S/N level?
It is COMPLETELY debatable whether or not the human ear can hear 1% or less THD.
The amp was rated at 100x4 @ 115 dB (4 ohms/channel).
Old Dec 6, 2005 | 04:17 PM
  #33
techmanBDsStang
Default RE: AMP
So that 115 dB is the s/n ratio? what did they test that at?
@full power? 1watt power?
What brand amp was it?
Old Dec 6, 2005 | 04:47 PM
  #34
pj1010's Avatar
pj1010
Default RE: AMP
It was one of the premier Powerclass amps of the time. Knockin on $1000, and it was still mediocore. I suppose I should quite arguing with non-SQ guys about what equipment they think they should be using.
Old Dec 6, 2005 | 05:15 PM
  #35
techmanBDsStang
Default RE: AMP
Ok then you don't want to answer my question. FIRST of all I am a reliability lab engineer for car amps. I do know what I am talking about.
This is why I was asking you these questions. Most likely what most amp companies do is give you a s/n ratio tested at full power where as the Infinity system is tested at 1watt. SO we need to bring it to apples and apples.
what was the power of the amp? around 800 watts?
db= 10*log(800/1)
db = 29
115 - 29 = 86 db S/N ratio from a $1000 amp. You are getting 81db S/N ratio from a $300 amp. You definatly will not here a difference at all with 5 db above.
Old Dec 6, 2005 | 05:40 PM
  #36
bigwille's Avatar
bigwille
Default RE: AMP
i got the speakers and a pioneer headunit pro installed at circut city. I went back the other day and i told him that the speakers were sounding "raspy" or "distorted" when i try to crank it. he said that its underpowered and i need an amp... i posted here and an engineer (you) gave a thumbs up on the amp........ case closed. ebay store is giving me the amp+3 year warranty+install kit for $300
everything else is warrantied at circuit city so i can blow em and get the new model as many times as i want
Old Dec 6, 2005 | 05:54 PM
  #37
pj1010's Avatar
pj1010
Default RE: AMP
db= 10*log(800/1)
db = 29
First and foremost, you are making assumptions at this point.
Old Dec 6, 2005 | 05:58 PM
  #38
bigwille's Avatar
bigwille
Default RE: AMP
ORIGINAL: pj1010
hes just got a lil sand in his vagina.. he argues in every1's post considering there all stupid compared to him
Old Dec 6, 2005 | 06:02 PM
  #39
pj1010's Avatar
pj1010
Default RE: AMP
ORIGINAL: bigwille
ORIGINAL: pj1010
LOL. You're a silly boy.
What evidence does he have that those ratings are at full power? He's making assumptions that are going to benefit his argument. I will be the first to admit I was "assuming" we were speaking on a level playing field, in that each company practiced equal QA. All I can do is "assume" (yet again) that specs posted on a particular site will be of equal weight. I cannot attempt to guess at PPI's tactics, thus I cannot refute his statement, much like he cannot make said statement with 100% validity.
Old Dec 6, 2005 | 06:57 PM
  #40
bigwille's Avatar
bigwille
Default RE: AMP
[sm=icon_blah.gif]
will the amp get me a nice sound out of these speakers or not....?
