Need help with 96 door panels
Old Dec 27, 2005 | 09:48 PM
jc96stang's Avatar
jc96stang
Default Need help with 96 door panels
I'm trying to replace the door panel speakers in my 96, but am having trouble removing the door panel. This car has crank windows, so can not figure out how to remove the crank, then the panel. Any one able to help? I would really appreciate it. Thanks
Old Dec 27, 2005 | 10:27 PM
Sinister Audio's Avatar
Sinister Audio
Default RE: Need help with 96 door panels
there might be a screw on the handle or you need a tool to remove the clip. then take the rest of the screws out of the door and push straight up on the door panel and itll slide up and you can pull it off.
Old Dec 27, 2005 | 10:51 PM
jc96stang's Avatar
jc96stang
ORIGINAL: Sinister Audio
Thanks. I just looked, and I don't see a screw. It is a plastic handle with a plastic gromet right up against the back side of the crank. I can't push the panel away from the crank to expose any clip or anything. Maybe as you said, looks like it may take a special tool. I was sure hoping not.
Old Dec 28, 2005 | 11:27 AM
p0rsche23's Avatar
p0rsche23
if ur still having probs ill look at my manual when i get home,its pretty simple but i have p/w,p/l so im not sure about the handle...prolly a simple clip or screws to undo behind it like sinister said..
Old Dec 28, 2005 | 05:27 PM
DR8907's Avatar
DR8907
not to jack this thread but what size are the speakers in the door?
Old Dec 28, 2005 | 06:12 PM
Sinister Audio
5X7
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
