Subwoofer wiring
Old Jan 9, 2006 | 02:40 AM
MadDog717's Avatar
MadDog717
Default Subwoofer wiring
okay...I wired my subs different and they seem to be hitting harder but I want to know if it will hurt anything
P3001 amp 2 rockford fosgate P2 subs...
output a + to left sub +
output a - to right sub -
left sub - to right sub +
bad? good? I read somewhere that you can do that but I'm not 100% sure. feedback is greatly appreciated. Thanks!
Old Jan 9, 2006 | 02:46 AM
TimmyGt's Avatar
TimmyGt
Default RE: Subwoofer wiring
that will work fine. there are a 2 was to wire subs to make them work. If you want to know 100% that this will be fine I will have to look up a few things (Like ohms & watts junk like that).
Old Jan 9, 2006 | 03:03 AM
MadDog717's Avatar
MadDog717
sub(s)= 4 or 8 ohm 200watt rms/400 peak
amp= 150x1 rms @ 4 ohm and 300x1 @ 2 ohm ( 900 watt max power) It's a mono
Old Jan 9, 2006 | 03:35 AM
TimmyGt's Avatar
TimmyGt
by the way you have them running is series wiring . this will be fine you are running 8 ohms which will be about 75 watts that the amp will put out. The higher the ohms the harder it hits but the watt will be lower.
Old Jan 9, 2006 | 06:33 PM
MadDog717's Avatar
MadDog717
Thanks
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
