Door panels
Old Jan 11, 2006 | 05:31 PM
baddog671's Avatar
baddog671
Default RE: Door panels
Yes, I was proud of my quick idea but I got a better one. Take your door frame off and lay it on the ground with the back side facing you. Take seran wrap and line the inside of it. Then take the yellow insulation stuff in a can and fill in all the area that is open space. Once you let it dry, you can peel it off the wrap and you'll have a perfectly molded insulation peice for your car. Godammit I should have patents for my ideas. You could make one exactly the same for your other door.
It would be better than the insultion too becuase it would be one large peice instead of awhole bunch of insulation crap in bags that wil fall out. Just make sure you put like 1 small screw in the insulation to secure it to the door and decrease chances of it beating around if it inst perfectly snug.
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
