HELP ME plz!
Old Feb 2, 2006 | 01:09 PM
MrChurch117's Avatar
MrChurch117
Default HELP ME plz!
im runin a 92 notchback stang and the factory radio wont work so i instaled a sony gtx220 and the player reads failure manual for the player states that this means theirs a problem from the wiring to the speakers how hard is that to fix?
Old Feb 2, 2006 | 01:38 PM
stangcrazy's Avatar
stangcrazy
Default RE: HELP ME plz!
It depends if it came with a factory amp. If so it is probably easiest to rewire your speakers. I might be going out on a limb here, BUT if your competent enough to install the Head Unit then you should be able to rewire your speakers fairly easily. Although rewireing the door speakers can be a pain, its not that bad.
Old Feb 2, 2006 | 04:54 PM
waxyourboard's Avatar
waxyourboard
You probably just have a wire crossed somewhere or grounded out. First check out the wiring right behind the head unit
Old Feb 3, 2006 | 12:24 PM
MrChurch117
well instead of dealing with the wiring in the package (major PAIN) i purchased the converter from ford factory to sony head so im kinda sure its not that close in. but ill check anyway tnks.
getnmineinmay
Apr 6, 2005 12:15 PM
supertrooper4
SVT Forums
Sep 18, 2004 03:24 PM
mustang_2004_65
Oct 21, 2003 11:18 PM
