foglights
Old Feb 11, 2006 | 02:49 AM
four-sixer's Avatar
four-sixer
Default foglights
To install foglights, is it as simple as take out the black piece in each of the holes and there will be wires waiting? Or am I hoping for too much lol
Old Feb 24, 2006 | 08:14 PM
Remmy's Avatar
Remmy
Default RE: foglights
Nope. Sorry to tell you that.
Old Feb 25, 2006 | 06:59 PM
tictac's Avatar
tictac
kinda. the adapter is there behind the plate, however your still going to need to run the wiring for the fog lights. our sponsor VMP has a great kit to do just that..
http://www.vmptuning.com/cart/home.php?cat=9
i used the kit to install fog lights in my cobra bumper. it took about an hour, which included installing the fog lights. it might have taken less time if i wouldve jacked up the car though.
hope that helps.
Old Feb 26, 2006 | 12:40 AM
David88vert's Avatar
David88vert
Actually, I did fogs on a 94 V6 back in 1994 rather quickly. I grabbed the factory fog switch from the dealership (I believe that it was $26 back then), plugged it in, then went to the fuse/relay box under the hood (driver's side), plugged in a standard relay (had to trim off the plastic mounting tab), then the plugs behind the plastic plates in the bumper were live. Cut the plastic plates and flushed in a set of fogs, looked stock, and took less than 30 min to do.
Old Mar 5, 2006 | 02:54 AM
Melectrok's Avatar
Melectrok
Even if wires are there you cant use them. Most aftermarket systems have to high of an amp draw for the stock subdistibution system.
tbray0331
Aug 14, 2015 11:10 AM
akatsume
Jul 22, 2005 03:05 PM
Halfpint5.0
Jan 27, 2005 04:19 PM
artisan00
Dec 7, 2004 10:04 PM
HuMp
Mar 15, 2004 01:26 PM
