Post pics. of...
Old Feb 18, 2006 | 12:42 PM
  #31
1fastzook's Avatar
1fastzook
Default RE: Post pics. of...
pretty much a capacitor is a waste of money i would get a better battery like a stinger,odyssey,northstar,kintiek, they are drycell batts and they have more reserve capacity charge quicker than normal batts "wet and gel cell".i would suggest getting a better alternator like a ohio generator or a stinger
Old Feb 19, 2006 | 12:23 AM
  #32
TimmyGt's Avatar
TimmyGt
I have a better battery check it. I still have to take pics of my subs and amp.
http://www.cardomain.com/ride/2223060/2
ORIGINAL: 1fastzook
Old Feb 19, 2006 | 12:49 AM
  #33
Jimmz's Avatar
Jimmz
Capacitors arent a waste of money, they give you better/quicker bass response from your amp.... its ideal to have a cap, optima battery and a bigger alternator....
Old Feb 19, 2006 | 02:42 PM
  #34
1fastzook's Avatar
1fastzook
caps suck if you listen heavy bass because it has no reserve capacity once you play your music drain the cap witch isnt hard your wasting all of the voltage to try to charge up the cap when it should be going amps.a cap is more of a band aid then anything.i build compeition cars and you harldy see a cap in their cars .
Old Feb 19, 2006 | 03:47 PM
  #35
Jimmz's Avatar
Jimmz
Well, a cap, alternator and a better battery is a must for a quality souund system....
Old Feb 19, 2006 | 04:57 PM
  #36
1fastzook's Avatar
1fastzook
all you need is some alts and batts i dont do SQ i like mine loud
Old Feb 20, 2006 | 12:34 AM
  #37
bonesninja's Avatar
bonesninja
waiting on a nice warm sunny day........................throw in my kick panels and MB Quart tweets glassed in the a-pillars plus optima yellow top, HO Alt, 2/0 ga wire, Big 3 wiring kit. Thats my 15" XXX, Alpine CDM-7871, Autotek mean machine 100.4, Autotek mean machine 1400.1, and my CDT Audio EF51neo's also toss in my memphis active crossover
Old Feb 20, 2006 | 12:53 AM
  #38
TimmyGt's Avatar
TimmyGt
ORIGINAL: 1fastzook
+1 if you put a better alternator and a bigger DEEP CYCLE Battery you will have more power then any system need. also it does still take power from the car to charge the cap and power the amp. the cap just hold a charge and once you turn on the sysem it going to start pulling from the battery to keep it charge which ruins the point of paying $200 for something that does so little.
better alternator and a bigger DEEP CYCLE Battery is all you need
Old Feb 20, 2006 | 03:27 PM
  #39
bonesninja's Avatar
bonesninja
ORIGINAL: TimmyGt
ORIGINAL: 1fastzook
It also helps to upgrade your electrical wiring. if you upgrade your battery and alt and leave the stock wiring then you are still limiting the amount of juice you can pull and could even cause a fire. The big three is an outstanding upgrade for high power stereo systems. This consists of a battery to alt connection, a battery to ground connection and chassis. to block connection. i use 2/0 ga and threw a fuse in-between the battery and alt. also.
Old Feb 20, 2006 | 03:29 PM
  #40
bonesninja's Avatar
bonesninja
here is a good link to those looking to upgrade to the big 3
http://forums.caraudio.com/vb/showthread.php?t=124175
baddog671
Jul 26, 2016 01:20 PM
1Bad71
Sep 30, 2015 07:37 PM
guitarman376
Sep 30, 2015 05:54 PM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
