remote turn on???
Old Feb 20, 2006 | 11:30 PM
Sickspackstang's Avatar
Sickspackstang
Default remote turn on???
where else can i hook up amp turn on to besides my power line? just need an idea
Old Feb 21, 2006 | 12:27 PM
bonesninja's Avatar
bonesninja
Default RE: remote turn on???
You can simply run it to your fuse panel inside the car ...just find an ignition controlled slot or accessory slot. If you do it like that then the amp will be on if the car is running or in the accessory position. If you want the amp on only when the deck is on then you will need to hook the amp remote to the deck's remote turn-on lead.
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
Sep 30, 2015 12:39 PM
logan409
Sep 26, 2015 07:43 PM
