Small Sig Change Please
Old Mar 22, 2010 | 11:11 PM
83gtragtop's Avatar
83gtragtop
Default Small Sig Change Please
This goes towards Xeno since he such a great job with my sig.
I really like the sig you made me but I was wondering if you could make one small change. Could you give my car that artistic look that your car has? I think that it would make my car blend in much better with the Grateful Dead art.
Thanks alot in advance,
Brian
Old Mar 23, 2010 | 09:06 PM
Xeno's Avatar
Xeno
'Dr. X'
here's how it turned out... hopefully it looks ok
Old Mar 23, 2010 | 10:36 PM
83gtragtop's Avatar
83gtragtop
Is there any way you can make it more defined? When I compare the image of my car to yours, it seems like yours is more detailed. Is there any way to make mine look like yours?
Thanks again for working with me Xeno, I'm a pain in the ***.
Old Mar 23, 2010 | 10:44 PM
Xeno's Avatar
Xeno
'Dr. X'
i can try something, but it may not get much better. usually, the way it eventually turns out is determined on the lighting/position of the original picture; but i can try a thing or two to smooth out the lines a little. i think i just got lucky with the way mine turned out
if it still looks weird after i update it, post up the original picture again (if you still have it) and i'll try doing the same thing with it; sometimes a larger pic will give better results
Old Mar 23, 2010 | 11:01 PM
Xeno's Avatar
Xeno
'Dr. X'
here's about as good as i can get, but like i said, if it still looks off, i can try using the original pic if you still have it
Old Mar 24, 2010 | 03:26 PM
83gtragtop's Avatar
83gtragtop
Thanks for trying again, I guess it's still a bit off. Could you please try it with this image?
Also, is there any way you could put a pattern in the background of the entire image, kind of like you did on your sig? Something that flows with the rest of the sig?
Again, thank you so much for working with me Xeno.
Brian
Old Mar 24, 2010 | 09:49 PM
Xeno's Avatar
Xeno
'Dr. X'
i think the full picture turned out better. the first sig is the old style with the updated car and in the second i added a psychedelic style background
Old Mar 24, 2010 | 10:58 PM
83gtragtop's Avatar
83gtragtop
Looks awesome Xeno, thanks alot!!
Old Mar 25, 2010 | 09:11 AM
07 Stang's Avatar
07 Stang
83GTRagtop, the best way to capture pictures of your car is to take it on a cloudy day or at sunrise or sunset. When you take pictures in the middle of the day, the sun washes out the true colors as well as much needed highlights.
Try taking some more at different angles.......just a suggestion.
BTW, my sister had an '84 black on black Ragtop.
Old Mar 25, 2010 | 05:52 PM
83gtragtop's Avatar
83gtragtop
Ya I'm aware. I have tons of photo's of my car on cloudy days, I just happen to like this photo, although I know it's a bit washed out. I have alot at different angles too.
Here are some shade photo's.
mtgldr
Feb 3, 2024 09:00 PM
9550
Oct 26, 2015 05:01 PM
Luke9222
Oct 22, 2015 11:55 PM
jaiidutch
Sep 14, 2015 10:29 AM
MusicCity615
Sep 12, 2015 07:05 AM
