where to find rims at??
Old 07-20-2009, 05:29 PM
phish
phish's Avatar
Default where to find rims at??
i am looking for a more modern style rim for my 65 black coupe. what is the correct bolt pattern for that car. it also seems that there are not many options for a 65. are there adaptors??? what bolt pattern can be adjusted so they can fit?? sorry for sounding like an idiot but i am kinda new to all this
phish is offline
Old 07-20-2009, 05:39 PM
Tony R
Tony R's Avatar
is it a 4 or 5 bolt?
Tony R is offline
Old 07-20-2009, 08:00 PM
ky
America ftw
ky's Avatar
5x4.5"
theres almost an infinite amount of options for wheels.
but if its a 4 lug then youre right, not many wheel options. 4 lug cobra r's are the only ones worth getting if you dont want to convert to 5 lug
ky is offline
Old 07-20-2009, 10:27 PM
1slow67
ROTM Moderator
1slow67's Avatar
He would still have to buy adapters and still there is a chance they won't fit.
4 lug classic - 4x4.5
4 lug fox - 4x4.25
1slow67 is offline
Old 07-21-2009, 01:25 AM
tx65coupe
tx65coupe's Avatar
I would just get some wheels that fit the car right to begin with.
I don't trust spacers any farther than I can throw them.
tx65coupe is offline
Old 07-21-2009, 10:36 AM
phish
phish's Avatar
i have a 5 lug rim. i dont want torq thrust rims i dont want elanor style rims. i see them too much. i am looking for something a little diferent. i am just not sure how to begin to look for them. what bolt pattern and offset is acceptable??? any help would really be appreciated
phish is offline
Old 07-21-2009, 12:19 PM
1slow67
ROTM Moderator
1slow67's Avatar
5x4.5 bolt pattern
Can go up to 4.5" backspacing on the front and 5-6" on the rear. The rear you might have to cut a piece of metal on each side, but I doubt it.
Check out tire rack, summit racing, jegs, discount tire.
1slow67 is offline
Old 07-22-2009, 10:19 AM
tx65coupe
tx65coupe's Avatar
BA is correct the lug pattern is 5 on 4.5.
15x7 4.25 backspacing is what I have on mine with Mag 500 and that is the correct backspacing for this combination.
Old 07-23-2009, 02:03 AM
phish
phish's Avatar
hate to sound like an idiot, but i think i kinda am.....that being said what bolt pattern, offset , and size am i capable of adding. i am so lost at this stuff. i just dont want to walk into butler tire and have them rip me off. i wold appreciate all the help i can get. i need to know what size tire and rim i am capable of adding.
phish is offline
Old 07-23-2009, 03:24 AM
tx65coupe
tx65coupe's Avatar
You can go with a 16 or 17 inch wheel and still have the car look right. Alot of the newer wheels will require a spacer to get the right backspacing.
Also, if your car does not have power steering then I would not go wider than 215 or 225 front depending on the wheel you go with.
Personally I would not go larger than 16.
Here are some wheel fitment charts.
http://www.dodgestang.com/Tire%20Fit...ide%2065-6.pdf
http://www.mustangbarn.com/tire.html
Quick Reply: where to find rims at??
