Hood pins
Old Nov 19, 2009 | 08:57 PM
bigred59's Avatar
bigred59
Default Hood pins
I have a '69 coupe with a mach 1 hood. It is factory drilled for hood pins. What is the cleanest way to install the plate onto the hood. I was thinking pop rivets. Also how do you find out where to drill the core support for the pin holes. Do you just close the hood and use the hood hole as a guide? Also I have seen the lanyards mounted in different places. What I am looking for is how the factory did it.
Thanks
Rick
Old Nov 20, 2009 | 05:14 PM
Stepman's Avatar
Stepman
If I read that right....this is not a stock hood. If you make sure it is lined up with fenders and cowl, then, yes close hood and mark core. Plates are attached with screws....that's all I got for now.
Oh...there should be a hole in the core for the lanyard.
Old Nov 20, 2009 | 05:59 PM
bigred59's Avatar
bigred59
Thanks for the info.
Old Nov 21, 2009 | 04:45 AM
Carlos Pineiro's Avatar
Carlos Pineiro
I have the same hood on a 69 coupe.
Check out this thread:
https://mustangforums.com/forum/clas...hood-pins.html
And a detailed post in the thread:
https://mustangforums.com/forum/5747401-post30.html
You may not want to rivet the bezels (they were designed with screws), since they will need to come off for paint. Also, screws are more watertight. Good luck.
CP
Old Nov 21, 2009 | 03:20 PM
4reboy's Avatar
4reboy
Yes I believe the bezel is supposed to be secured using screws. I thought that was a sure thing until my dad and I noticed his 428cj car has his bezels riveted in... and it looks like it could be a factory job (but probably not). My car has a plate on the top side of the hood and also a plate on the bottom side that the screws go into. If you like everything up you can use a hood as a template, with the size of the hole you are supposed to use there is probably about a 1/4" adjustment or more in all directions to get it lined up perfectly. The pin is secured with two large bolts and washers each.
Old Nov 21, 2009 | 03:56 PM
bigred59's Avatar
bigred59
Thanks for all the great information.
Old Nov 26, 2009 | 08:52 AM
andrewmp6's Avatar
andrewmp6
Every set of twist locks i seen where screwed on never riveted yet.
Old Nov 27, 2009 | 05:57 PM
bigred59's Avatar
bigred59
Thanks for the info. I have them installed now and used stainless steel screws.
Old Nov 28, 2009 | 01:34 AM
andrewmp6's Avatar
andrewmp6
How do they look take some pictures of you can.
BOB ROME
Jul 26, 2023 01:54 PM
PaulH2
20
Jan 31, 2016 09:48 AM
Nov 18, 2015 01:34 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
