How to know if i have a single point...
Old 03-20-2010, 11:29 PM
ashtoncrabtree
ashtoncrabtree's Avatar
Default How to know if i have a single point...
Hi my names Ashton im working on my 66 mustang 289.and im wondering about the distributor, im still learning various things and this is one of them i want to up grade this area with a petronix 11 ignition system. because sometimes my starts arnt so easy. if im not making full sense just ask me for more detail.
ashtoncrabtree is offline
Old 03-21-2010, 12:08 AM
hiboostwoody
hiboostwoody's Avatar
Pop the distributor cap off and see how many sets of points are inside the distributor. It's pretty likely that you do unless your car is a Hi-Po or a Shelby or unless someone put in a dual point kit at some time. Of course, I am assuming that your distributor is stock and not an aftermarket one.
hiboostwoody is offline
Old 03-21-2010, 01:24 PM
ashtoncrabtree
ok thanks i took some pics out and compared them with other pics and yes mine is single,, now i want to upgrade it to a petronix kit would you suggest the petronix 1 or the petronix two im just driving it everyday no racing.
http://s762.photobucket.com/albums/x...923091740a.jpg
that is my engine but it is not a acgtually hipo because i only have a two barrel carb, but some work was done to the car before i got it so if that would make a difference on my selection of a pretonix unit
Old 03-21-2010, 03:02 PM
JamesW
Moderator
JamesW's Avatar
Have to take the distributor cap off to see if it's a single or dual points unit. 99.999% sure it's a regular single point distributor. I'd go with the simple pertronics I kit and enjoy the benefits.
follow the instructions closely.
JamesW is offline
Old 03-21-2010, 05:30 PM
4reboy
4reboy's Avatar
I believe you should just get the pertronix 2, it's newer so I assume it's better technology. Just be sure you get the correct coil to match the unit and wire everything up properly.
4reboy is offline
Old 03-21-2010, 10:58 PM
ashtoncrabtree
ok i took of the cap and looked around yea its single and the only reason i lean towards the petronix 11 is because i was told it wont burn out if you accidentally leave the key on wether or not that is true would be my descion maker.
Old 03-21-2010, 11:41 PM
hiboostwoody
I have absolutely no experience with Pertronix at all so I can't give an opinion other than to say either one would be a vast improvement over the points system you currently have.
Old 03-22-2010, 09:09 AM
toybreaker
toybreaker's Avatar
Either one will work for a daily driver. I have used both on several different engines.
I currently have a petronix I in my 70. Works great. accidently left the key on for 3 days and once i charged the battery everything works fine.
toybreaker is offline
uberstang1
09-20-2015 06:42 PM
Daddys Girls GTs
09-14-2015 08:46 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: How to know if i have a single point...
